 HELP NEEDED >
HELP NEEDED
HELP NEEDED
Old 05-09-2004 | 12:01 AM
pauluk2w's Avatar
My Feedback: (7)
Default HELP NEEDED
i am thinking of strengthening the fuse on my nexstar but im not sure on the best way to do it and what the best material would be to use. i have had a few rough landings and the landing gear is holding up with no signs of weakness but i have heard all the horror stories about this being a problem.
Old 05-09-2004 | 12:19 AM
Banned
Default RE: HELP NEEDED
If it ain't broke... don't fix it.
Old 05-09-2004 | 09:16 AM
FFhuber is right, you would have to remove the covering around the landing gear area.
Old 05-09-2004 | 09:55 AM
blw's Avatar
blw
I can't remember how the NextStar is built, but you definately should check if it uses nylon bolts. They are meant to break away on really hard landings. Breaking off usually means not ripping out the fuselage bottom.
