Prop Q
Old 05-24-2004 | 07:41 AM
Default Prop Q
Hey guys,
For my RV-4 i wanna put a 3 blade prop onto it to make it look sa-weet, so for a 2 blade i would use a 11X6 but ill put a 3 blade 10X7 on it. My question is since ill be putting a new .46FX onto it, it says to use a 10X6 2 blade to break it in... what exatly is the point of this?
~Matt
Old 05-24-2004 | 07:44 AM
MinnFlyer's Avatar
Default RE: Prop Q
That's so you don't overload the engine during the critical break-in stage.
You give it a chance to run with a prop that is relatively easy for the engine to spin.
Old 05-24-2004 | 03:45 PM
Default RE: Prop Q
ok so it is esential i use this first then go to the 3 blade? or can i use the 11X6
Old 05-24-2004 | 04:21 PM
MinnFlyer's Avatar
Default RE: Prop Q
I would stick with the recommended 10 x 6 for break in. Just get a cheap wooden one and run a few tankfulls of fuel through it, then switch to whatever you want.
Old 05-24-2004 | 06:36 PM
Default RE: Prop Q
sounds good thanks Minn
~Matt
