 Spinner Question >
Spinner Question
Spinner Question
Old 06-19-2004 | 08:12 AM
Default Spinner Question
I can't seem to be able to get my standard 2-blade 2 1/4" Vortech spinner to fit my Saito 72 engine. I plan to use a 13x6 prop, so I was going to have to cut the holes out just a little to make the prop blades fit, which doesn't seem to be a problem. The problem is that the spinner calls for the short 7x1mm adaptor nut (S710-8710) for any spinner 2 1/2" and under, but the adaptor nut won't screw down far enough to even touch the washer that holds the prop up against the backplate. Am I missing something or do I really need the LONG adaptor? I just wanted a nice shiny looking spinner for this thing and Great planes don't even show any adaptor nuts for the Saito 72. Do I have to resort to spending a little more for a Tru-Turn spinner?
Old 06-19-2004 | 11:11 AM
MinnFlyer's Avatar
Default RE: Spinner Question
Can't you use the regular nut, then put the adapter on top of it?
Old 06-19-2004 | 04:14 PM
Thanks, actually that looks like it's going to work!
