TS91AR .91 engine
I have this engine, and my question is do i have to put the high speed needle on it? Because my 4*60 has a little opening for the low speed valve, but for the high speed valve it wouldnt fit in there, so anyways i rather not use it.
Ok , what i did was put the high speed needle behind looking down instead of the normal way which would be horizontally. This way it fits perfectly, the valve will be easier to reach from behind, and now i ask you if there's anything wrong with doing it that way.
