Wing loading...
OK
It is simply the amount of weight each square foot of wing surface must carry. If you had a ten pound airplane with ten square feet of wing area, the wing loading would be one pound per sq. ft. It's usually given in ounces for our models. A sailplane may have a wing loading of 10 or 12 ounces, where a scale warbird's loading may well be over 30 ounces. Just divide the weight by the wing area.
Also these could be of some help.
There's 16 ounces in a lb. And there's 144 sq. in. in a sq. ft.
So figure your area by multiplying span by chord. Ex. 12"chord 48" wingspan = 576 sq. in. Now divide by 144 to get sq.ft. which equals 4 sq. ft.
Then figure your weight in oz. So lets say 3 lbs 9 oz. 3x16 = 48 oz. added to 9 oz. = 57 oz.
Now that you have those two numbers you can find your wingloading in oz./sq.ft. Which would be 57 oz. divided by 4 which comes to 14.25. So your wingloading is 14.25 ounces per square foot.
Hope that made it simple.
Josh
Josh
My Feedback: (7)
Wouldn't it be nice if the wing loading was expressed in the same units as the plane's units?
When was the last time you saw a plane spec like this:
Wingspan 7.5 feet
Wing Area 7.80 sq ft
Weight 175 oz
Or when did you ever see?
Wing loading: .00980 lb/sq in
Wingspan 7.5 feet
Weight 175 oz
OK
I think we're so used to ounces per square foot we'd have to do a conversion before we'd have any idea what our wing loading was! I know I have to mentally convert kilometers to miles before I can get a feel for how far it "really" is. I also tend to convert ounces to pounds if the ounces get much over 60 or I'm lost. Tell me a plane weighs 128 ounces and I've got to change it to eight lbs. Same with millimeters. I have to do a quick rough headspace conversion before I can sense a 12 mm something is a bit less than half an inch. I wish I'd grown up metric, as it IS much simpler!
One point here is the higher the number the more of a missle it will be and size does not matter. I had a Lanier Stinger 120. Wingloading was somewhere aroun 9 or 10. Although a large plane it floated around and also on landings. I have a little DC F-20 Tigershark with numbers in the 30's. It is a flying bullet with no glide ratio and lands hot and fast or you will stall and crash.
OK
I find size DOES matter. The larger the plane, the higher the wing loading can be and still retain good flying characteristics in my experience. I can imagine the smaller Tigershark with a high wing loading would be quite a handful.
My Feedback: (16)
GA
Wing loading is of importance to some aircraft and not so important to others. For Jets and some WWII aircraft high wing loading is expected and is not a big issue. For gliders and sail planes, wing loading is very important and the lighter the better!
OK
I find it rather amazing that a fully loaded modern fighter/bomber has a wing loading about like a manhole cover! (ok.. personhole for the politically correct?) Raw power overcomes a lot.
I think when it comes to full size then it's a matter of Reynolds numbers, sort of a scale affect. The bigger the wing the more efficient it becomes for the same air speed.
For models though I find that the lower the wing loading the better which is why I use quite large wings and build as lightly as I can (within reason
My Feedback: (16)
GA
I have had a Extra with a 72 inch wing and I now have one with a 80 inch wing. Their weights were about the same but I find that the 72 inch flys and lands better and the 80 inch presents better when flying sequences. The difference is slight and could be attributed to the engine.
