 Changing mufflers >
Changing mufflers
Changing mufflers
Old 07-16-2004 | 07:30 PM
RichD's Avatar
Default Changing mufflers
I had the misfortune of losing the back half of my muffler yesterday on my maiden flight of my somethin' extra. It has a TT .46 pro engine. I aquired an OS muffler, and after a very minor adjustment to make it fit, it is on securely. The OS muffler is physically shorter, and smaller in diameter. I also removed the baffle.
Will the new OS muffler, due to its smaller size, not let my engine run to full throttle? Do I need to readjust the carb? Still learning the tuning of engines, so if so, I will have to get some help tomorrow at the field.
RichD
Old 07-16-2004 | 07:50 PM
Razor-RCU's Avatar
My Feedback: (50)
Default RE: Changing mufflers
It should need very little adjustment- Is the substitute muffler from a 46FX or similar? It is similar in size and shape to the TT pro-46
I would recommend the Tower muffler though for another 600-1k RPM's [X(] Its' only $13-
Old 07-16-2004 | 09:11 PM
RichD's Avatar
Going to order a mac pipe next week, just trying to figure out something for this weekend.
Old 07-16-2004 | 09:15 PM
ORIGINAL: RichD
Are you going to use a mousse can (good idea) or a tuned pipe? (bad idea)
As long as you have the front part of the muffler,
www.plasticwings.com (the new spadtothebone)
has the PERFECT fix for you. You can finish it in a couple of hours.
Old 07-16-2004 | 09:28 PM
I agree, that is the best 14.00 you can spend in this hobby if you have a 46. They also blot up to an irvine 53. The tower muffler gives my engine about 150 rpm more than the macs muffler. I don't know what the difference would be between the tuned pipe and the tower muffler. I just went to towers site and they won't be available until late Jul. Too bad since mine fell off the other day.
ORIGINAL: Razor-RCU
Old 07-16-2004 | 09:33 PM
RichD's Avatar
ORIGINAL: MasterSmasher
Thought about the mousse can several times. How big should the exaust hole be?
