 4-40 threaded pushrods >
Old 07-17-2004 | 06:43 PM
Default 4-40 threaded pushrods
I was just wondering if it is all right to use a 4-40 threaded pushrod on my control surfaces with one end using a Du-Bro ball joint and the other end using a Du-Bro Kwik link?
Old 07-17-2004 | 06:49 PM
Default RE: 4-40 threaded pushrods
I don't know much about ball-joints but I would go with a regular clevise if I were you.
Old 07-17-2004 | 07:50 PM
Ball joints are good but i saw one come off today,it's your choice but i think a clevis would be better.
Old 07-17-2004 | 11:07 PM
My Feedback: (85)
if you want to use ball links go with the sullivan they are spring loaded and will not come off accidently.
Old 07-18-2004 | 07:23 AM
What size plane? 2-56 rod is plenty for a .40 -.60 size plane. 4-40 rod really isn't needed and will add a little weight.
Old 07-18-2004 | 10:54 AM
I prefer good ball links on all my planes, especially the 1/4 scale or larger. They are more precise and much more reliable than clevises or zbends. You should have no trouble with the use you describe.
Old 07-19-2004 | 07:59 PM
If you are referring to the Dubro links that thread on and have a bolt going down through a ball socket into the control horn. Go right ahead. I am going to use them on my RCM Advanced Trainer that I am currently building. They are very strong and precise. If you mean a ball and socket type hook up I agree they are better off not being used. Sullivan's look ok but i still would not trust them. Good luck.
Mark Shuman
BTW go ahead and use the 4/40 stuff. It is a little heavyer yes. But much stiffer and all in all would make the plane more responsive.
