easy sport 40
ON, CANADA
guys, whats up with this easy sport 40 from great planes. they give you a choice to build it as a tricycle or a tail dragger version. i built it as a tail dragger. one i finished the plane i weighed the plane and it was within the weight range. i tried to balance it an she was all tail heavy, no blobs of glue no added weight in the back. if i decide to add more weight in the front, now she will be even heavier. any ideas on this?!?!?!?!?!?[:@]
TN
Don't worry about the final weight. You HAVE to balance it. If it means adding weight, that is what you will have to do. Before adding weight, reposition your battery pack and receiver and see if that helps. I've not bought many planes that weigh in what they are advertised. They are almost always heavier.
ON, CANADA
hey red i did all that. i just dont get it. this is the second plane a ibuilt my other easy sport 40 i just gave it away cuz i thought it was just defective. very dissapointing. but in this case, do you this i should just add weight regardless? let me know. thanx 4 your reply.
ON, CANADA
actually i do red, i was using the new os engins (46 ax) lotsa power!! i have the 160 fx i can try. but that puts out tooooo much power. take care. happy flyin.
I have an Easy Sport I built about four years ago. It is built as a tail dragger and covered with Koverall and dope. Power is an older model MDS 46. It balanced right on with no added weight and is one great flier. There is much room to move equipment to get the balance right, however if you don't want to move stuff, a little weight in the nose won't hurt anything.
ON, CANADA
hey lou. i never mentioned this time i never balanced the plane, my other easy sport that i had was 100% tail heavy, so this time i went and bought another one, built it tried to fly it and crashed into a school wall. (uncontrolable).[
ON, CANADA
call me dumb, i just thought it was defective[:-] with this plane i also had the thing sheeted in cloth and resin to give it a nice paint finish, im not big on monokote, i figured this was the problem, so when it was time to balance it, she was all tail heavy. so i just decided to give it to a friend. his time ill just use monokote and balance it and take it from there.
