 easy sport 40 >
easy sport 40
easy sport 40
Old 07-26-2004 | 08:43 AM
adam d's Avatar
Default easy sport 40
i'm am building a great planes easy sport 40 and i have a question. no where in the instructions does it say to put on fiberglass wing reinforcement. should i put some on just in case?
Old 07-26-2004 | 09:37 AM
MinnFlyer's Avatar
Default RE: easy sport 40
You don't need to worry about it. If GP doesn't say to use it, then the plane is engineered to be strong enough as is.
If you WANT to use it just for peace of mind, go ahead and add some, but it shouldn't be necessary.
Old 07-26-2004 | 10:39 AM
adam d's Avatar
thanks because i was'nt shore
Old 07-26-2004 | 01:48 PM
GrnBrt's Avatar
If you look at the center sheeting you will see it's all one piece, no seam in the middle and there's your strength. No glassing needed.
Old 07-27-2004 | 07:17 PM
The canopy/fuselage wing mount also adds to the center strength of the wing. I have seen several of these beauties take a cart wheel with out the center section being affected.
You are going to be happy with the final product what ever you decide.
