Steering Front Wheel
CA
Hi,
I once saw an add for a device that was installed in the spring of the front wheel assembly.
You then hooked the control rod from the servo to this device.
Does anyone know who makes this device and where I can get some?
KW_Counter
KW_Counter
CA
I can't find them.
I found the Servo Savers, that isn't what I'm looking for.
This device attached through the spring on the front wheel assembly and stuck out to the side so the control rod could be attached to it.
KW_Counter
KW_Counter
CA
I found it!!! I found it!!!
It is a Du Bro E/Z Mount Steering Arm.
anyone ever use these?
Thanks for the help.
KW_Counter
KW_Counter
The arm has threads on it and screws into front gear, works well and stiffens front gear and makes it more riggid. I thought it may have been the over ride.
