 Prop Shim >
Prop Shim
Prop Shim
Old 08-16-2004 | 03:44 PM
Default Prop Shim
I bought a Graupner Prop with the 8mm hole. It is a little bigger than the shaft on my Evo .46. What is the best way to shim it to fit? Thanks.
T/A
Old 08-16-2004 | 03:47 PM
WCB
Default RE: Prop Shim
I've used electrical tape before. Wrap it around the shaft then trim so the washer will seat against the prop. Never had a problem.
Old 08-16-2004 | 05:01 PM
i agree,electrical tape or plumbers teflon tape works well.
Old 08-16-2004 | 05:04 PM
Thank you for your support
