How to fix the tail wheel? >
Old 05-06-2002 | 10:30 AM
Default How to fix the tail wheel?
Hi,
I have (maybe a stupid) question. I've glued the bent music wire on my rudder to fix the tail wheel. But how can I fix the tail wheel to the music wire? I can slide the wheel on it, but what keeps it from sliding off? Do I need to bent it again?
Old 05-06-2002 | 01:26 PM
ysrcflyer's Avatar
Default tailwheel
All you need is a wheel collar the same size of your music wire. Slide the wheel on and then the wheel collar and tighten.
Old 05-07-2002 | 05:21 AM
Banned
Since you have already attached the bracket... there's only a few options.
The above wheel collar method needs a bit more explaining... to connect the steering to the rudder, replace the set screw with a 1 inch or longer machine screw. Bend a wire "yoke" to cradel the screw and link to the rudder for steering. A bit of fuel tube on the screw acts as a slight shock damper. (more of a "feels good" than actually does any good...)
If the rudder isn't on the plane yet, you can extend the tailwheel wire up appx 2 inches above the bracket, make a 90 deg bend close to the bracket, and another 90 appx 1/2 inch from the end of the wire. This last bit gets imbedded in the rudder using epoxy, then a strip of light fiberglass or medium silk over the wire and bottom of the rudder will lock it all together.
There's also a way to drill a second set screw hole in the wheel collar and affix it using two 1 inch screws, then springs from pens for a fully shock isolated steering link on the tailwheel. (look at some of the fancier tailwheel brackets... same idea, just inexpensive..)
Old 05-07-2002 | 06:11 AM
Default thanks
thanks for your precise explanation!
