 which color more visible >
Old 08-23-2004 | 02:39 PM
knightmagic's Avatar
Default which color more visible
Was thinking of 2nd plane the slo poke arf but the colors are white and blue was wondering how hard it would be to see while flying[img] [/img]
Old 08-23-2004 | 03:59 PM
daveopam's Avatar
My Feedback: (9)
Default RE: which color more visible
The plane your talking about has a lot of wing and a good size profile. It's pretty easy to see. I once had a Fun-One covered in sky blue with red accent. The blue was easy to see. Even against the blue sky. The red was terrible. I should have used more of a contrast. Like white or bright yellow.
David
Old 08-23-2004 | 05:20 PM
ballgunner 's Avatar
The most visible color is international orange. You don't have to paint the entire airplane with it. Perhaps just the wing tips, a fuselage stripe or the rudder and elevator or the cowl.
Old 08-23-2004 | 06:25 PM
The overcast gray sky will be the only problem. I usually put underside wingtip strips of fluorescent orange trim sheet. I built the original kit with yellow and dark blue trim scheme. The gray sky turns it two shades of black. White with red trim seems easiest for me to see.
