"official" solo
WA
"official" solo
Friday went out with instructor. had the landing down so-so, and wanted to practice touch and go's since it's required to be soloed. was having quit a bit of trouble with the approach, from 50' out to that landing, as the plane slowed it became harder to maintain the right slope. (hope these are the right terms) Brought it in, instructor rechecked the CG. Ended up throwing 3/4 of an once on the tail. HUGE IMPROVEMENT!!!! She glides in so nice now. Got the touch and go's down.
Saturday got the club prez to check me out, 2nd instructor required for solo, and didn't have one prob. Said I'm good to go. Did have to do my 1st forced dead-stick. Went nice.
Thanks to everyone for all the help. Reading about so many different experiences here made me a better pilot from the 1st time I put hands on the Tx.
Couple things: Planes absolutely covered in oil when done. I'm talking dripping and stuff. This normal? Possibly rich on the high end? (EVO PTS .46)
Landing a lot easier with a closer last turn, instead having to maintain proper elevator and throttle management for 600' to touchdown.
My Feedback: (12)
SC
RE: "official" solo
ORIGINAL: ActionVerb
Oil on the plane is normal. That's why the electric crowd calls glow powered planes "slimers". It is not a sign your engine is too rich. I carry a roll of paper towels in the flight box so I can wipe some of the slime off the plane. In addition to the paper towels, I carry a bottle of spray cleaner to degrease the plane at the end of the day. That way it's clean when I get home and all I need to do before the next flying session is charge the batteries. Another useful addition to the flight box is a tube of waterless cleaner. Helps get rid of the slime from your hands before driving home. I'm using stuff called "Simple Green", spray and hand cleaner. Many other brands are available.
Something that might help reduce the slime is an exhaust deflector. It's a piece of tubing you slip on the end of your muffler to help direct the exhaust away from the plane, or at least in a direction to minimize the amount of slime on the plane.
GA
RE: "official" solo
Congrats on the Solo!!
I just came upstairs to get some fresh air...as I am building my first plane right now... Whew! Epoxy stinks!!
I'm stressed but loving it....
Again Congrats! Hope to join you in the "SOLO" ranks, before too long!
RE: "official" solo
Cute Andy.
Action,
Congrats on the solo, it only gets better from here on out.
You could still be a bit rich, sounds like excessive "slime" to me, but you'd be better off adding that exhaust deflector that someone else mentioned, than leaning the engine anymore, especially if you're happy with the performance.
Dennis-
Action,
Dennis-
WA
RE: "official" solo
thanks all.
NICE. So when I grease my landing we're talking literally and by the end of the day the planes leaving a slug trail. I use Windex with about a teaspoon of dishwashing liquid (which I read about here) so I'm able to get it cleaned up but the slime coating always seems to be on there. Had to repair my firewall recently so removed some covering on bottom of the fuselage. I couldn't get the new covering to stick, despite cleaning it with acetone, so just fuelproofed it with thick CA.
And I have the deflector, so Im doing all I can, so since it's preforming well I'll leave it alone.
Don't wipe that slime off! It helps the plane slip thru the air! And if you don't have enough, you can't side slip into a landing!
MI,
RE: "official" solo
Congratulations. Just be careful for awhile. It seems like some of the new fliers at our field have been ending up in the trees lately.
I add some ammonia to those orange degreasers, but ultimately, there is always some "slime" left. good luck
Michael
Michael
RE: "official" solo
Try baby wipes. They generally cut through that slime, I mean, that's what they were designed for right?
The wipes do leave a bit of streaking behind, but a quick swipe with "Windex" or similar gets rid of that if you care. I've had decent luck getting covering to stick by wiping down with alcohol first.
Dennis-
Dennis-
WA
RE: "official" solo
multiple times while flying I have to say to myself, "You're new, you're green, don't get over confident and remember, **** happens fast!!" Now I'll add "altitude and airspeed" to that.
excellent! I should have though of that. With a 4 month old in the house we have a few million baby wipes sitting around.
PA
RE: "official" solo
I would be careful about the exhaust extension. a small-(less than 1 inch ) would be ok to get the stream out of the way but the ones availible often cause more back pressure& certainly heat build up of your motor. some times you get away with it but it can be an ultimately expensive way to solve the problem.best is to side mount the engine & even use a "pitts style muffler for minimum accumulation.something you have to live with on glow power. pure rubbing alcohol is cheap & works well.
