 u s aircore trainer >
u s aircore trainer
u s aircore trainer
Old 10-04-2004 | 03:08 PM
Default u s aircore trainer
whats the best glue or cement for this plane?? plastruct plastic weld doesn't work!!
Old 10-04-2004 | 03:27 PM
exeter_acres's Avatar
Default RE: u s aircore trainer
Do the instructions not say??
I would assume a mix of epoxy and CA depending on where or what??
What exactly are you trying to do?
Old 10-04-2004 | 03:56 PM
instructions say to use u s aircore contact cement but i can't find any!i'm going to try "AMBROID REGULAR CEMENT". i read that other people used it and they liked it.
Old 10-04-2004 | 08:25 PM
Jim C.'s Avatar
good luck with that plane.... i had one and it was garbage. and yes, it was built correctly
Old 10-05-2004 | 06:52 AM
use contact cement. epoxy won't do anything for that plastic. check out the spad forums...you'll get more answers there.
Old 10-05-2004 | 11:13 AM
Bax
You can use the same kind of contact cement as you would use to apply high-pressure laminates to plywood when making countertops for your kitchen. The non-flammable kind is recommended. Paint it onto the areas to be glued, allow it to dry, and then press the pieces together. Just be careful to get the pieces lined up properly. You can put a piece of paper between the dried, glued areas and then pull it out when they're lined up.
