 Cold weather, no start. >
Old 10-05-2004 | 07:05 PM
Default Cold weather, no start.
I have a TT Pro 46 and a OS 46fx. Both of them usually start within 2 or 3 flips when they are cold. Last night I went up to the field. I bet I flipped both of them 100 times and couldn't get either to start. I got to thinking that the only thing different from any other time was that it was pretty cool outside. It was around 50 degrees. Hoping that the temp was the problem. I got my bic lighter out and held the flame on the carb for about 20 seconds. Then flipped the engine and it started right up. I couldn't believe that 50 degrees was enough to give me engine troubles. Anyone else have this problem. Any other suggestions on how to get them started in the cold?
Old 10-05-2004 | 07:28 PM
jettstarblue's Avatar
Default RE: Cold weather, no start.
A prime shot of zippo lighter fluid never fails.
Old 10-05-2004 | 07:30 PM
That and an electric flipper....
Old 10-05-2004 | 08:46 PM
Rubberduck's Avatar
I had the same problem last night with my plane (Evo .40 engine)...wouldn't start very easy. finally got the thing running, but it wouldn't stay running. Messed with the high & low needles without much success. We had it running good on the stand, but as soon as we tipped the nose up in the air it died.
Spent an hour messing with it tonight (20 degrees warmer), and it runs like a champ.
So I'll echo bodypilot's thoughts: Any other suggestions on how to get them started in the cold?
Old 10-05-2004 | 10:46 PM
50 degrees shouldn't cause a problem at all, that shouldn't even be noticeable... Most of my engines won't act any differently until at least 30, and i've never had to prewarm any engine at all, even down to about 10F
Old 10-06-2004 | 05:53 AM
Last fall, at our last Fun-fly of the season, it was pretty cold at about 35 degrees with a stiff breeze, and a lot of people had trouble geting engines started, myself included. I found that I had to richen the high speed needle nearly a full turn to get it running properly.
Cooler air is more dense than warm air and can throw off the tuning, especially if the temp difference since you last flew is 20 degrees or more. Try richening the needle. (But I agree, 50 degrees shouldn't cause hard stating.)
Dennis-
Old 10-06-2004 | 06:55 AM
That comment is pretty much my expirence also
Old 10-06-2004 | 06:59 AM
tIANci's Avatar
In Malaysia its warm all year round ... we can fly everyday. Anyone wants to migrate? Hehehe ...
Jett ... when you mentioned Zippo fluid what do you mean, into the carb or you light the engine up a bit?
Old 10-06-2004 | 07:03 AM
Iam not JETT but yes thats what he means.
Put a drop or 2 of lighter fluid in the carb
before you start it.
Old 10-06-2004 | 07:09 AM
tIANci's Avatar
With all that heating up the engine talk I was thinking the Zippo fluid was for ... hehehe ...
Old 10-06-2004 | 07:19 AM
Yeah, I have a can in the box for PRIMING the engine. Not warming up the engine, Hendix style!
You should also re-tune the needle valve(s) for about every 10 degrees F (slightly homer!)
Old 10-06-2004 | 07:55 AM
exeter_acres's Avatar
Has anyone used Car engine starter spray instead of zippo??
I forget exactly what it is called, but it is basically an ether spray (IIRC)
Its the stuff you spray directly into a cars carb to get it to fire
(Nascar fans would have seen the pit crews using it if the tank has gone empty)
Old 10-06-2004 | 07:59 AM
Rubberduck's Avatar
Ether is correct
Old 10-06-2004 | 08:08 AM
tIANci's Avatar
One of the guys at my field loathes one of his planes ... I wonder how it would fly ala Jimi Hendrix Hey before anyone bashes me I am just kidding!!!
Old 10-06-2004 | 08:39 AM
Quick Start is the ether-based automotive product & it works well at -20C with an electric starter. My engines (mostly TTs) start to get a bit fussy for flip starting below ~+2 or 3C, without Quick Start. They need to be well primed to start, but they also flood a bit more easily at those temps.
Old 10-06-2004 | 08:33 PM
All of the above and try using more nitro. More nitro will help when it gets cold. Retuning of course is mandatory.
Mark Shuman
Old 10-07-2004 | 12:02 AM
Years ago a small amount ( about 5%) of white gas (aka unleaded) in the fuel did wonders. I don't remember any negative side affects, so if someone knows of any, holler quick.
Old 10-07-2004 | 06:58 AM
ORIGINAL: tIANci
Yes!!
The trick here is to paint the plane with rubber cement, or contact cement....it doesn't go out once lit, even with considerable airspeed.[X(]
Old 10-07-2004 | 07:11 AM
50 degrees! WHAT LUXURY! I live in northern Alberta, Canada and we have been know to fly at -40 degrees. We did it on a New Year's day just to say we were the first to fly that year. I don't recommend flying at -40 though. It's really brutal. We do fly often at below zero temperatures with skis on the aircraft. I usuually keep the plane in the warm vehicle until I am ready to fly then quickly start it up. Some fliers put the engine under the car exhaust for a few minutes if it is really cold. I don't put any special additives in the fuel though. I just try to have a well broken-in engine and have it adjusted properly.
Old 10-07-2004 | 08:34 AM
Cyclic Hardover's Avatar
You want some advice then take this, buy an electric hand starter, I run some of the best engines around (OS,TT, ST, Jett etc) yet even the best do not necessarily start good at all. Your wasting your time with a chicken stick and getting frustrated. You can end this now or get upset every time you go fly. Besides engine performance is better when it's cooler.
ORIGINAL: bodypilot
Old 10-07-2004 | 08:54 AM
tIANci's Avatar
Jettstar ... are you taking from experience? [X(]
Old 10-07-2004 | 08:59 AM
Deadeye's Avatar
ORIGINAL: Cyclic Hardover
ORIGINAL: bodypilot
Not to mention flight characteristics. Dense air = Better flying. A 'Mongo Mitt' also works well to keep the hands warm. I've flown at -20 F before. For several hours.
