4 star 60 or Tiger 60?
OK
I've been flying since May of this year. I went from a 40 size trainer plane to a Sig Kadet Sr. Flew it for a couple months and now am flying a VMAR stick. I am doing very well with the stick and have flown it about 15 - 20 times now successfully. I'm not real impressed with the quality of this plane and want to get a new one with a 4 stroke engine. I'm deciding between the Goldberg Tiger 60 or the Sig 4 Star 60. Anyone who's flown both of these have any suggestions and motor recommendations?
My Feedback: (13)
I flew a Tiger 60 with a ST 61 on it for quite some time. Absolutley loved it.
I've flown but never owned a 4*. They to are great flying planes.
I would recomend the Tiger, but that is just my opinion. Both planes fly about the same and have the same general flight abilities. I think it boils down to which one looks better to you.
If you wanted a four stroke the New Saito 82 would be just about right for either of these planes. Agian thats just my opinion
OK
Thanks Chassan: I'm leanding toward the Tiger. I like the way both of them look, I guess I'm a little torn between tail dragger or trike gear...
My Feedback: (13)
You can mod both to get the gear you want. Not hard to do. I've seen more Tigers modded to tail dragger than 4* modded to trike gear.
Basically you just get some aluminum gear and mount them so the axels are under the leading edge of the wing. Pick up a tailwheel and mount that on the back and you are good to go. There should be some good posts around here that go into more details.
I would also like to correct myself. The Saito 82 would be a good engine, but you might be more pleased with a 90 or 91 4stroke. if you wish for unlimited vertical even a 100 would be ok.
When I get my new one (been saying that for 6 years since I dorked the old one) I'm going with a 91 I think.
Ahh the memories.
Ahh the memories.
OK
I have not flown the tiger but I do have the 4* 60 powered with a ST .61. I love it. It flys like a dream, however I think I will be looking for more power in the future. But for now, it has enough power to stay with my ability. I've been solo for about 4 gallons.
http://www.rcuniverse.com/forum/Tige...2232520/tm.htm
This is my post on a Tiger 60, with pictures and mods. I built mine as a taildragger, it has great ground handling, flies well. I have even trimmed my hedgerow with it twice, with no damage except to my pride. I am still searching for the best prop combo for it.
TX
Just for the record, I was rooting for OU all the way!
ORIGINAL: twistr
2slow, am I going to have to come down there to Texas and whip your ***** like OU did to TX???
I prefer the Tier 60. The T 60 is set up for either trike or tail dragger landing gear. Go with tail dragger. Much more durable. The T 60 has a positive decent rate so it is easy ito land in windy conditions. The 4* doesn't want to lose altitude unless it is almost at a stand still. This makes landing the 4* in windy conditons a bit more tricky. The T 60 will fly faster and is a smoother flyer. ITs slightly more expensive but the higher performance is worth it.
