 which for the 40LA? >
which for the 40LA?
which for the 40LA?
Old 10-21-2004 | 06:16 AM
Default which for the 40LA?
Hi
im fed up with my trainer, i havnt flown it for months now. Ive been flying why DJ3 + Super air.
i want to bin the airframe, and im not sure which plane to put it in:
Flair Magnattila
Flair Atllia
Weston UK Couger 2000
Sportsman Avation HotKnife
GP Patirot (if i can find one in the UK)
Irvine Wild Card
Blackhorse Sukhoi SU-31
Blackhorse Cap 232
Blackhorse Extra 300S
Blackhorse Spitfire 40 ARTF
This is wht i ahte about AFTFs!!
Which would you choose if any?
Old 10-21-2004 | 07:36 AM
Default RE: which for the 40LA?
A .40 LA makes a great doorstop, why inflict it on an unsuspecting airplane?
Old 10-21-2004 | 07:58 AM
The 40LA is a good stunt engine, if you're into control line. I got the CL venturi and NV from Tower Hobbies, trashed the remote needle valve and ran it in my 'Tanager' until it attempted to drill a new oil well. Now it is in my ARF Nobler.
Glen
Old 10-21-2004 | 08:26 AM
Sorry for the wisecrack about the LA 40 -- I just couldn't resist it. However, the point that I am attempting to make is that if you are bored with a Superair powered by an LA .40, you will be quickly bored with the others if you use the same powerplant. The Superair is much more exciting with something like a TT .46 Pro in it, and that is a good way to start raising the excitement level.
A word of caution -- unless you fly well & are also prepared to do some significant mods to the horizontal tail, avoid the BH Spitfire. It is prone to shedding its elevator from flutter. Even if you fix that problem, it is a real handfull on take-off & landing, plus it snaps hard if you apply too much elevator at high speeds --- not a toy for an inexperienced flyer. I had to trim off the balance tabs, double all of the elev hinges & sheet the stab & elev with 1/32 balsa to stiffen the tail of my BH Spit. If you can live with the mods & tricky low speed handling, it is really fun to fly (as long as you respect its flight envelope). Again, a TT.46 Pro, or something similar, is what is needed for the Spit to perform well.
Old 10-21-2004 | 10:02 AM
(The super air has a 46la in it.)
Old 10-21-2004 | 11:48 AM
ok i think i know what im going now:
the 40la goes into a HotKnife
the 46la stays in the super air
i will get a Jen 56 to go into a VMAR Exta
