Sig LT 40 Mods >
Sig LT 40 Mods
Sig LT 40 Mods
Old 08-19-2002 | 02:21 AM
Default Sig LT 40 Mods
I have seen posts on bashing the LT 40 but can't seem to find them , want to change to bolt on wing and convert to tail-dragger remove some of the dihedral and clip the wing anybody done any of these mods
Old 08-19-2002 | 08:59 PM
Here's a thread on the LT40 that may help. Just do a search on LT 40
http://www.rcuniverse.com/showthread...ght=lt+40+mods]
Old 08-22-2002 | 01:26 AM
To stiffen up the tailfeathers, use some triangle stock between the horizontal stabalizer and vertical stabalizer. When adding the triangle supports use a sharp razor blade to cut away the Oracover on your kadet, and make a wood to wood bond with either CA or epoxy... I used Epoxy for that extra stiff bond. You can either paint the tri-stock to match your plane's scheme or pick up a Monokote trim sheet and apply that to it.
Happy Landings!
-Brian
