Thunder Tiger trainer 2000
Hi all.
Could anybody out there tell me how far back from the leading edge is the Cof G position on a Thunder Tiger trainer 2000?
Crashem.
Thanks for the information, I will balance at the point you suggest then fly the model and make any necessary adjustments.
Hi Jeff, if you have the manual that came with the plane, ususally the cg and the throw rates are listed toward the end of the instruction manual, sometimes on the very last page. If you really can't find it, balancing for a slightly nose down position using the main spar of the wing will work. For my planes I look for the nose to tilt down about 2" from centre when holding the plane up with your finger tips. [8D]
Hi Fastsky.
Thanks for the information,unfortunately I do not have the manual.I have balanced the model on the main spar as suggested by yourself and a couple of other people on the forum and I intend to fly it at the weekend.Thanks for all of your help.
Jeff, I assume thast you are planning to meet up with an experienced pilot for your flight training?? If so, great!!! Have fun and let us know how it went.
