 Wing Twist Problem >
Wing Twist Problem
Wing Twist Problem
Old 12-11-2004 | 08:45 PM
Default Wing Twist Problem
I am assembling my first kit a Goldberg Tiger 2 and everything was going fine with the wing assembly untill now. everything was aligned perfect , i was using the provided supports to build the wing, the 2 halves were joined without incident. Actually i was just about done with the wing and had it off the table to do some sanding -when i set it back down tonight on the supports i built it on- the right trailing edge corner is about a half inch off the supports and the rest of the wing sits level. what can i do? the wing has been perfect for two days and now its twisted, what causes this, and is my wing beyond hope?
Old 12-11-2004 | 09:47 PM
My Feedback: (85)
Default RE: Wing Twist Problem
depending on what kind of glue you used yellow or white glue. try misting it with water and setting it on the jig and weight it down for a couple of dats to dry. also when you cover it with iron on covering you can twist the wing back that way. Good Luck
