Difference between servos
Can someone explain to me the difference between the Futaba servos? I understand there are different size and torques and major stuff like that, but some of the differences seem more obscure. Like the difference between the S3001 and the S3004. Does ball-baring make a difference? What is all the core-less stuff about?
If this is more than a post can handle, could you provide a refference where I could read about these things?
Zee
Zee
the ball race makes the servo output stay wobble free for longer, i used them on my Diamond dust where any slop will = flutter and you crash and die.
but... then you get into 148 vs 3003 debate, the 3003 is newer, has smaller electronic components and is better in most respects, its also cheaper than the 148. Because the 148 still has some processes done by hand apparently.
after that you get more and more powerfull servos, these are ones you use when you go bigger or faster
My Feedback: (16)
GA
FlyingZee,
I am not an expert.
GO to the link below to get your questions about terms answered.
http://www.futabarc.com/glossary.html
I am not an expert.
