Problems programming Hitec optic 6
ON, CANADA
I just recently got the Hitec optic 6 radio and have been trying to program flaperons into my Somethin' Extra when all of a sudden I realized that the left aileron servo had barely any movement. My first thought was there was something wrong with the servo. To check this I swiched channel 1 and 6. When I did this the left aileron servo had plenty of movement but now the right aileron servo hardly moved at all. I spent a while trying to figure out what the problem was. I went thorugh all the screens to see if anything was unusual, but everything seemed to be in line. If anyone else has had this problem or knows how to fix it, any help would be apreciated
ON, CANADA
What do you mean when you say the travel control. I know that all of the channels have the EPA set to 100%. Other than that I don't know what other travel controls there coud be.
ON, CANADA
Never mind, I figured out what the problem was. It turns out that I had aileron differential programmed into the lef aileron. Now that, that is fixed everything is working fine
