 another field charger question >
Old 03-21-2005 | 09:26 PM
Default another field charger question
hey everyone, If your field charger has an option to charge your battery from 0.2 - 2.0 amps which do you choose? For example: if I have a nicd or nimh battery of 600mah how many amps should I charge it? etc... Thank you
Old 03-21-2005 | 09:36 PM
My Feedback: (13)
Default RE: another field charger question
Choose something less than 2 times the capacity. In your case two times 600 equals 1200 mA or 1.2 Amps. Choose a setting close to 1.2 Amps and a totally discharged pack should take about 30 or 40 minutes to charge. If you choose a higher setting, it will charge faster but is harder on the pack. If for some reason you are in a big hurry, you can choose 3 times (e.g. 1.8 amps) and it should charge in only about 20 minutes. But I generally don't go more than 2 times for NiMh.
Old 03-21-2005 | 09:42 PM
thanks, is this the same with nicd packs? and i'm just curious on how you are determining how long it will take ( besides the field charging beeping at you etc..)
Old 03-21-2005 | 10:14 PM
My Feedback: (13)
Yes, NiCd and NiMh you can pretty much treat the same. NiCd is generally more tolerant of being overcharged, but the NiMh is also quite good about taking a charge at a low rate (C/10) or up to a 2C rate.
Old 03-22-2005 | 06:15 AM
NiMH packs should never be charged above 1C. NiCDs can be charged at 2C, but I don't do it. It shortens the cells life.
There are NiCD cells rated for fast charging that will take 2 or even 3C, but few of our packs are built with these cells unless you order them specifically.
Dennis-
Old 03-22-2005 | 10:12 PM
My Feedback: (16)
Set it to 0.6 amps
ORIGINAL: NJAIRSTRIKE
