props
Old 03-31-2005 | 10:17 PM
Default props
When you install the prop is the sharp side the leading edge. for instance the airscrew prop do you install with the logo forward or the sticker?. Boy am I green
Old 03-31-2005 | 10:22 PM
Default RE: props
the molded information (brand, size, etc.) should be away from the engine--the nut should tighten up agains it. I'm assuming you're talking about a traditional front mounted engine, and not a rear-engine "pusher." The prop will turn counter-clockwise when looking at it from the front. While turning that direction, it should blow air back, toward the aircraft. The leading edge will be the fat edge--just like a wing's airfoil--and will taper toward the trailing edge.
Old 04-01-2005 | 09:54 AM
Pilot Chad's Avatar
Default RE: props
the master airscrew or what ever the logo is goes on the outside.
Old 04-01-2005 | 03:48 PM
Default RE: props
thanks guys
Old 04-01-2005 | 04:25 PM
Default RE: props
There's an "outside"? Outside what?
Old 04-02-2005 | 04:56 PM
jettstarblue's Avatar
Default RE: props
"Logo" FORWARD.....
Remove the sticker and balance the prop. On Master Airscrew, it's a good idea to lightly sand the leading and trailing edges, or they'll be calling you two fingers.
Old 04-02-2005 | 05:57 PM
Default RE: props
or better yet, just look at the airfoil and decide yourself which way is forward. some props might have a sticker/logo on the back.
Old 04-02-2005 | 06:40 PM
Pilot Chad's Avatar
Default RE: props
Yeah, my prop ends got sanded down... Damn prop strikes...
