 How many Hinge points....... >
Old 04-02-2005 | 04:27 PM
a65l's Avatar
My Feedback: (17)
Default How many Hinge points.......
I'm replacing the CA hinges on an airplane with Robarts Hinge Points. The alierons have 3 CA hinges per surface, should I use the same number of Hinge Points, or go with 4? Is there a hard and fast rule for the # of hinge points to use per inch of control surface, or is this just an experience thing? BTW, the plane is a 120 size warbird, so it's not going to be expected to do any (intentional) violent aerobatics, or fly (again, intentionally) very fast.
Thanks in advance,
Andy
Old 04-02-2005 | 04:32 PM
Default RE: How many Hinge points.......
My general rule of thumb is to duplicate whatever hinge count the orig plan calls for or 1 more. It is a kind of "feel" thing. The hinges are plenty strong. Duplicate the orig placement and then an extra close to the control horn. I use the Robarts whenever the T.E. structure permits.
Old 04-02-2005 | 05:59 PM
depends on the size of the model, but at least 3 for any surface, and usually one every 3 inches. larger models cna get away with fewer, my 1.20 stinger has 5 or 6 on the ailerons, which span 40 inches
Old 04-03-2005 | 09:24 AM
Fastsky's Avatar
Thinbking about it I use one every 3" as well. [8D]
