Q&A first micro plane
hey fellow rcuni members,
my name is kurt, sn is protron, nicname is pro.
im getting into the rc hobby.
i own a avistar trainer .60 ARF
i enojoy building stick planes for fun like guillow pk kits.
id like to get some of them flying.
plz help me with some Q's
[hr]
Kits:
25" guillow p51 ( first built airplane, its gonna go to hell in the matter of minutes)
32" guillow f4u coursair (half built)
20" guillow stuka (dead sexy model)
22" guillow cessna (micro trainer)
[link=http://www.guillow.com/]guillow pk[/link]
[hr]
Radio:[&:] Q?
hitec LASER 4 Four Channel FM Aircraft/Surface Radio
Stock # 156723 Micro System
Includes : Feather 4 Ch.
Micro Receiver,
2 HS-55 Micro Servos,
600mAh Transmitter NiCd,
Dry AAA Receiver Battery Box,
A/C Overnight Wall Charger
[hr]
fly kit:[:'(] Q?
[link=http://shopatron.com/product/product_id=RCD27770/110]flight kit[/link]
Hitec RCD X-16 Speed Control Flight Pack-Negative Shift: Hitec and Futaba Transmitters
X-16 Speed Control Flight Pack-Negative Shift for use with Hitec and Futaba Transmitters Contains 2 HS-55 Servos, Electron 6 Receiver, Multiplex MultiCont X-16 16amp Proportional Electronic Speed Control.
[hr]
Motor:[:@] Q?
[link=http://www.hobby-lobby.com/speedplus.htm]speedplus[/link]
SPEED 300 7.2V with Controller
GR6365 Graupner Motors & Controllers SPEED 300 PLUS, 7.2V with
Controller ..... $ 42.90
IN STOCK
The motor is GR7302 SPEED 300. See the description under Motors. The motor controller is proportional, has BEC. For 6 or 7 cells and 5 amps max.
size 300?
[link=http://www.hobby-lobby.com/brushless-uberall.htm]hobby lobby b-less motors[/link]
NEW! Special external rotor motor for 1 Lithium cell, complete with controller!
Nippy Black 0803 External rotor brushless motor with controller
UBR0803 Uberall Nippy brushless motors"Nippy Black" 0803/199 Brushless Motor with Controller ..... $ 159.00
IN STOCK
1-5/8" diameter, 1-1/2" long (from prop backplate to firewall mounting surface), 4mm prop shaft, 1.23 oz. Special design for lightweight flying on a single Lithium Polymer cell or 3 Nicad or NiMh cells. Due to the low voltage, a special controller with BEC is supplied with this motor. Suitable for models up to 10 oz. Use APC props of 8x3.8 to 9x4.7. Maximum sustained current 8 amps. Includes very lightweight aluminum motor mount.
size 400+
[link=http://www.hobby-lobby.com/brushless-combo.htm#Nippy1208]motor + esc[/link]
The power of a geared 400 without the gearbox!
Nippy Black 1208 External rotor brushless motor
UBR1208 Uberall Nippy brushless motors"Nippy Black" 1208/180 External Rotor Brushless Motor ..... $ 69.00
IN STOCK
1-5/8" diameter, 1-1/2" long (from prop backplate to firewall mounting surface), 4mm prop shaft, 2.14 oz. Direct drive design. Use with 6-8 cells and a Jeti 18 Amp controller and APC props from 7x4 to 9x4.5. Maximum sustained current 12 amps. Aluminum motor mount included.
COMBO: Order your Nippy Black 1208/180 with a Jeti 18 amp brushless controller and SAVE!
UBR1208 Nippy Black 1208/180 Motor $ 69.00
JESAP18 Jeti PLUS 18 Amp Brushless Control $ 75.80
Buy motor with controller and SAVE $ 11.40
[hr]
Q's
Is hitec reliable? do they have quality production?
i have futaba for my avistar.
what motor is best for inter-changable, for my kits?
can anyone tell me about amps watts weight recommendations for the airplane kits , sizes etc...
any other recommendations for motors? radios? kits?
I'll say a couple of things.
For a decent flying electric you'll want at least 75 Watts per pound of flying weight, closer to 100 Watts will get a very aerobatic bird.
However, the Guillows kits are known to make lousy flying planes, so do so more research before you actually try to convert one.
Try Ezone, they're exclusively electrics and have had many threads regarding Guillows conversions.
Good luck,
Dennis-
Good luck,
Dennis-
