 SSE Tank Help >
SSE Tank Help
SSE Tank Help
Old 04-11-2005 | 08:54 PM
Default SSE Tank Help
HEY, the tank on the SSE is pretty low to the engine carb, is that normal?
Old 04-11-2005 | 11:24 PM
Redback's Avatar
Default RE: SSE Tank Help
On my second SE, never had a problem or heard of anyone else either.
Terry
Old 04-12-2005 | 05:44 AM
Hi!
There is a simple rule that says: The center of the tank should always be in line with the fuel inlet orifice in the carb when the airplane sits horizontal!
If not...there will be problems!
Regards!
Jan K
Sweden
Old 04-12-2005 | 06:24 AM
Connery's Avatar
As long as it's not higher than the carb you will be fine. Mine is built totally stock and I've had no problems with it.
Old 04-12-2005 | 10:20 AM
yes but on the SSE the tank is alot lower than the carb, thats how its setup .. its not like Its purposely done.
Old 04-12-2005 | 10:49 AM
hookedonrc's Avatar
I built mine stock as well ...never had a problem with the engine operation, it runs great.
