 ASP engine >
ASP engine
ASP engine
Old 04-17-2005 | 12:28 PM
Default ASP engine
I have an ASP 61 engine, and I can't find out who the the
manufacturer is. I would like to find the specifications for this
engine, like low idle settings and the needle valave settings.
Can someone help me with this info?
Old 04-17-2005 | 12:41 PM
Skynyrd Man's Avatar
Default RE: ASP engine
I think it's Tower Hobbies which I heard is owned by great planes.
Old 04-17-2005 | 01:09 PM
EscapeFlyer's Avatar
ASP and magnum are manufactured by global hobbies. They are the same motor with a different name. Great motor!
Old 04-17-2005 | 01:53 PM
Thank You, it appears you are right about Global Hobbies, I have
found a website with some specifications.
Old 04-17-2005 | 02:00 PM
Hossfly's Avatar
The Asp engine may be a tad over-compressed. Previously distributed by Indy RC -- now extinct -- and the Horizon, I do not know who imports it now. The 40/46 are excellent but not long-life like a ST that never quits.
I have used the .75 and the .90 which were over-compressed. I do not know about the .61.
You can make another head gasket from a pop can material, cut inner hole with X-acto #11 blade and then trim the outer rim.
Easy to do and works well to decompress engines originally made for no-nitro markets outside the USA.
Don't worry about settings as the 2-stroke glow engine has its own mind there. Close the throttle to about a hairline open, and set the idle needle so that you CAN but BARELY blow air through the carb. Then open the carb and set the NV to where it will pass some air but not all at once. Go from there. Generally set the high end first. Sometimes one might need to leave the glow plug connected through the transition to open throttle to be able to set the high end. Once done very well there, start with very small idle adjustments.
May take some trial and error, however you will learn the code.
Suggest you start a flight at least 700 RPM down on the rich side. The ASPs are powerful engines. Overly lean can provide significant practice in dead-sticks. [8D]
Good Luck.
Old 04-17-2005 | 06:34 PM
Oop's, my bad. I thought you sad ABC. Sorry.
Old 09-01-2008 | 11:33 AM
anyone can help me
what is asp engine manufacturer website ?
Old 09-01-2008 | 04:37 PM
Hossfly helped you. Read his posts.
Global hobbies.
Search for magnum engines and you'll have it.
I've owned the 2 stroke 91 asp, great engine. Very high reving. I'm not sure they are still imported, though.
Old 09-01-2008 | 04:44 PM
Mr Cox's Avatar
These are good both for info and spare parts (but are located in the UK):
http://www.justengines.unseen.org/acatalog/ASP.html
Old 09-01-2008 | 09:35 PM
carrellh's Avatar
ORIGINAL: bambangr0996
The manufacturer is Sanye.
Sanye manufactures ASP, Magnum, Super Custom, and probably others.
I have no idea if they have a web site. You might try your favorite search engine.
Old 09-01-2008 | 09:38 PM
carrellh's Avatar
duplicate
