 first time flyer >
first time flyer
first time flyer
Old 04-23-2005 | 06:54 AM
Default RE: first time flyer
We can try.
Old 04-23-2005 | 07:53 PM
Old 04-23-2005 | 07:54 PM
Old 04-23-2005 | 07:55 PM
if you need some a little better let me know
Old 04-23-2005 | 09:35 PM
BuzzBomber's Avatar
That's an Evolution. I think it's a .46NT, but it could be the Trainer Power System engine--not sure if there's a difference.
Old 04-25-2005 | 07:31 AM
  #31
Definitely an Evolution. Does it have a black flywheel right behind the prop?
Old 04-25-2005 | 08:16 AM
  #32
Fastsky's Avatar
Jus a suggestion, looks like your fuel lines are very long! Try and shorten them up! You just want a bit tiny bit longer than a straight piece between the needle valve and the carb. You also have a huge loop between the fuel tank and the needle valve. Shorten that up as well. Will make for more reliable running. [8D]
Old 04-27-2005 | 06:06 AM
  #33
yes it does have a black flywheel. thanks for the help with the fuel lines.
Old 04-28-2005 | 02:27 AM
  #34
Definately an Evolution. As for the 46NT part? Is there any identifying numbers on the Cylinder wall, or under or on the mounting lugs?
99% sure it will be an Evolution 46NT. By what I hear, its a pretty good engine.
Old 04-28-2005 | 07:19 AM
  #35
OK, with the flywheel it is a trainer motor. Now at the top of the cylinder on the side there should be a size stamped. Probably a 46 or 61.
Old 04-28-2005 | 08:42 PM
  #36
ok i don't see anything like 46 no where on it, all i really see is the letter a on the side of it i'm not sure about under the mounting lugs. it came with another motor and it's blue and it says OS 46 LA but it looks a little smaller than the one that i have on there now especially the carb intake.
Old 04-29-2005 | 07:50 AM
  #37
Not really an "a" but the evolution logo. The 46's didn't use to have the sizes stamped on them as they were the only size made. Nothing to confuse them with. So I feel confident in saying you have an Evolution .46 trainer engine. IF you wanted to you could remove the flywheel but I believe you would need to purchase a new prop drive hub. Only major benefit IMHO would be that more spinner backplates would fit easily.
