 Automatic Glow Plug ignitor >
Old 05-15-2005 | 12:46 PM
HeyRobi's Avatar
Default Automatic Glow Plug ignitor
Where can I find a glow plug ignoitor thats automatic or on board I think it comes on at low throttle or at a push of a button!
Old 05-15-2005 | 02:03 PM
Default RE: Atomatic Glow Plug ignitor
i have circuit diagrams on paper and
sch files, my scanner has let me down once again.
I will get it to you when it works again
Old 05-15-2005 | 03:31 PM
HeyRobi's Avatar
Thank you, I look forward to seeing them!
Old 05-15-2005 | 03:35 PM
Right I desinged this for my GCSE project:
This is what you need:
Old 05-15-2005 | 03:42 PM
HeyRobi's Avatar
Hmm! That does't look too hard! Do you have a picture of the actual circuit so I can get idea of what it looks like in the end! Looks like all I need is a couple relays 3 resistors a variable resistor a cap and transistor!
Old 05-15-2005 | 03:48 PM
i have no pic yet.
Im still dong all the paperwork for the project.
No
you need the bottom cicruit.
The top circuit shows you when your fuel gets low, the smoke goes on
For this you need
a CMOS 4031B Duel D-Type FlipFlop
IRFZ41 Mosfet
Cap, and 3 resisters, i will let you all know what hapens wiht my project
Old 05-15-2005 | 03:51 PM
HeyRobi's Avatar
If you accidently make 2 let me know!!
Old 05-15-2005 | 04:30 PM
i can build you one on a PCB if you want....
(i will onl charge for materials, and shipping)
Old 05-15-2005 | 05:58 PM
HeyRobi's Avatar
That sounds more than fair to me! Send me an email with total cost and I can PayPal ya!!
[email protected]
Old 05-16-2005 | 12:10 PM
Default RE: Automatic Glow Plug ignitor
There are many made with many features. I have three different types. One of the simplest is the RAM igniter. You can buy it from Tower for a little over $40. It comes with a 1300 NiCAD, plugs for everything but charging plug. You install your own particular brand of male plug for the charging wire. Don't know why they just don't put on a universal male plug for you.
Expert makes one that is almost infinitely adjustable for about $50.00, without a battery. You have to hook everything up with screw posting wires to the unit.
Nelson makes a "Intelli-glow" (also without battery) that reads the resistance on the plug and provides power as needed (my favorite) you program it every time you turn on the receiver power for where on throttle position you want it to be active. Programming takes about 30 seconds or less. I am buying 4000 MaH, Single C cells from Radio Shack for the ones that don't come with batteries and just quickly solder the power leads to the systems power wires. You can install a mini 5amp switch, also from RS (about $5.00 for a pkg of two) to put between the unit and the glow plug, so the unit can be controlled positively for priming and so on. I have gone to OBG's on most of my planes over .91, since big glow engines, especially inverted can squench a plug when you come off the throttle and then back on too quick, usually when you don't want to go dead stick.
Some folks just hook a switch to a mini or micro servo and a simple battery and use the retract switch to turn the unit on and off as desired. This setup is the simplest, but doesn't give much backup. If you leave it on all of the time, the life of the plug is shortened some.
Happy Landings
Old 05-30-2005 | 12:19 PM
uro
What kind of potentiometer I need for the circuit (glow ignitor);(what size).
Thank you very much
