 Another comment... no air filter needed??? >
Old 05-26-2005 | 12:58 PM
Default Another comment... no air filter needed???
I am seeing many pics of planes, and none of them have an air filter attached on the carb?
Old 05-26-2005 | 01:00 PM
MinnFlyer's Avatar
Default RE: Another comment... no air filter needed???
There's not much dirt up there... Unless you live in LA
Old 05-26-2005 | 01:02 PM
CGRetired's Avatar
Hey, Minn.. how can you trust air you can't see... Hmmm?
Old 05-26-2005 | 01:16 PM
JohnW's Avatar
The only time you are at significant risk of sucking a lot of dirt into the engine is on the ground. If you fly from asphault or concrete, there is no need for a filter. Most grass runways are also typically clean enough that a filter isn't needed. I have heard of some that use filters becasue the site conditions warrant such, but in general, the vast majority of sites don't require a filter. One might think "why not just use a filter anyway." I have used filters before and they will rob power. I dropped 150 RPM when I used a filter on a YS140. 150RPM may not sound like a lot, but it equated to 0.15HP on that setup, or a 5% drop in power, just from the filter.
Old 05-26-2005 | 01:29 PM
ballgunner 's Avatar
I use filters all the time because we fly from dirt runways. If they were grass or paved I wouldn't bother with a filter.
Old 05-26-2005 | 07:08 PM
IBrakeForNobody's Avatar
My Feedback: (16)
I am required to use a air filter at all times because I use a airplane engine to power my truck and I like a drivin' in the dirt. [>:] But with my airplanes, I don't bother because where I fly, we take off from a 400' asphalt runway and there is no dust/dirt often (but there is fine dirt off to the sides of the runway)
Old 05-26-2005 | 10:07 PM
dick,
it's the air that you CAN see that you shouldn't trust
ORIGINAL: dicksoucy
