 Question about 4-strokes >
Old 06-09-2005 | 12:02 PM
Default Question about 4-strokes
I posted yesterday about a second plane and due to the response and what club members told me, I ordered the Sig Four Star 40. I'm interested in powering it with a 4-stroke. What's the appropriate size.....I'm guessing the .52. Are there any 4-stroke engines I should keep away from? I'm thinking about the OS just cause I've always liked their products.....what do you think? Thanks in advance
Old 06-09-2005 | 12:16 PM
Pilot Chad's Avatar
Default RE: Question about 4-strokes
a 52 to 56 is about right for a 40... I do however know that some people put 70's on 40 size, but i don't think you need that.
Old 06-09-2005 | 12:23 PM
bubbagates's Avatar
My Feedback: (32)
ORIGINAL: dsk
Last year I had the 4*40 and used the OS46Ax 2 stroke turning the 11X7 APC prop and the plane was a screamer. I then bought the Saito56 and went to a 12X6 and the plane did slow down some but still flew well. I did have tons of problems with the Saito (I never seem to have luck with them) so I went will the OS 4 stroke and same prop and the plane flew very well. Not tons of speed but gobs of pull and vertical.
It took a little getting used to going from a screamin' 2-stroke to the 4-stroke but block out the sound for a little while and just watch the plane and it all comes clear.
Old 06-09-2005 | 12:34 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Dsk,
An OS 52 Surpass 4-stroke would be a great motor for your 4*40. The great thing about a 4-stroke is that it's got a bit more "omph". You can swing a bit larger prop which will give you a little more power. Plus 4-strokes use less fuel than a 2-stroke. You won't get all out screaming speed, but since this is your second plane you probably don't need that anyway. I've got an OS 52 4-stroke on my GP Slow Poke 40 and I love it. I think you're making a great choice here.
Hope this helps
Ken
Old 06-09-2005 | 12:38 PM
bubbagates's Avatar
My Feedback: (32)
Thanks Ken, I couldn't for the life of me remember the OS 50 size 4-stroke DOH...
Old 06-09-2005 | 12:56 PM
Hey, thanks for the responses......another related question......I have about 5 different OS engines, ranging from .15 up to a .46AX....
In my old control line days, I always used Cool Power 15% and when I started getting into RC, the hobby shop guy said that 10% would work just fine. Well, it has.....in my budding career, I haven't had any engine problems....If I purchase the OS .52 4 -stroke, will the 10% be a good choice for fuel? Any fuel considerations for breaking the engine in? Thanks again
Old 06-09-2005 | 01:02 PM
bubbagates's Avatar
My Feedback: (32)
DSK,
the 10 percent will be fine with that engine. Just make sure the oil content is 18% or better. Personally I use 15/20 in my OS engines both 2 and 4 stroke
The oil I found that seems best is a blend of synthetic and castor and the Byrons fuels are all that way in the 10 to 15 percent nitro ranges (non-helicopter fuel)
Old 06-09-2005 | 01:03 PM
DTB's Avatar
DTB
My Feedback: (15)
The 4* is a great second plane. Years ago I built a 4*60 and put a YS .91FZ on the front spinning a APC 15x6. This motor is supercharged and has the power of a 1.20 4-stroke. It will hover, torque roll, flat spin (true flat spin), fly inverted, do blenders and does the best knife edges for the type of plane it is.
If you are a scale flyer, the a 52 or 56 4-strk would work and work fine, but if you like to 3D some, then I recommend a OS 70, Saito 72, 82 and even a YS 63. Tons of power in any of those motors and you will really love the plane more. Having extra power doesn't hurt and plus you don't have to fly at full throttle. My 60 size with a .91FZ is a perfect combo. For me atleast. I still enjoy flying the plane years after building it. I did add a few mods to my 4*60 such as counter balance rudder, pull-pull rudder, dual elevator servos, 1" addition to the control surfaces, bomb drop door in the front plus a few other changes.
See it here under the RC aircraft section:
http://derrick.myphotoalbum.com
Old 06-09-2005 | 01:14 PM
bubbagates's Avatar
My Feedback: (32)
ORIGINAL: DTB
OOOHHH YS power on a 4* holy crap...
Feed it high nitor contents and holy crap become OH MY GOD. That had to have been a phenominal mix. Heck I'll screw in my YS110 to my 4*60. The thing hauls my 11lb funtana around nicely, In the 4*60 I'd have a missle with big wings
Old 06-09-2005 | 01:44 PM
DTB's Avatar
DTB
My Feedback: (15)
ORIGINAL: bubbagates
ORIGINAL: DTB
Haha, I do run 30% in both my .91FZ on my 4*60 and 1.10FZ on my Funtana S90 also. The power that those engines have are unbelievable. You have a YS, so I'm sure you understand exactly what I mean. The 1.10FZ has power that you wouldn't think a 1.10FZ should have. My buddy with a FT90 who has a Saito 150 can't believe the power it has and would actually say is stronger than his 1.50. It is compared to the Saito 150 for power though.
My FT90 only weighs 8.62 lbs (dry) with a YS 1.10FZ. Think about how your 11 lbs FT90 flys and take off a couple of pounds and keep the same power plant using 30% nitro.
Simply amazing in flight. Does everything under the sun.
The 4* with good power is a blast too.
