 os 52 engine problem >
Old 06-24-2005 | 09:52 PM
Default os 52 engine problem
Hi guys,ive got my os 52 idleing and reving good,but when i taxi down the runway for lift off,the engine seems to lose power(rpm's) at about half to three quarter throttle.All my fuel lines are fine,ive blown fuel threw the needle valve assembly,im bewildered,has anyone seen this happen and can help?
Old 06-24-2005 | 10:59 PM
Default RE: os 52 engine problem
Your high speed needle is probably out of adjustment. Try richening it a little if that don't do it lean it a little.
Old 06-25-2005 | 05:09 AM
My Feedback: (13)
You're lean. As the prop begins to unload, you're picking up some extra rpm. This is normal, but the engine is getting too hot and sagging.
Open up (turn counterclockwise) the needle valve about a quarter turn, then do the lift test:
With someone holding the plane in a normal horizontal attitude, run the throttle to max. Let the engine stabilize at max power, then point the nose straight up. If the engine stays running strong at max, the mixture is okay. If not, tweak the needle valve until it does.
Old 06-25-2005 | 01:38 PM
Thanks guys.
