CA or Epoxy?? >
CA or Epoxy??
CA or Epoxy??
Old 10-15-2002 | 03:35 PM
Default CA or Epoxy??
Hi,
I am assembling a Sig Kadet Mark II (my first plane). I just finished the right wing and used only thick and thin CA glue. Should I be using epoxy on the wing to make it stronger? When do I use epoxy vs CA?
Regards
hwflyer
Old 10-15-2002 | 03:38 PM
MinnFlyer's Avatar
CA is fine for the wing panel construction. But use 30 min epoxy when it comes time to glue the two wing panels together.
Old 10-15-2002 | 04:08 PM
the ca will be fine for the wing panels but use 30 min epoxy to join the wing halves and also when attatching the tail feathers to the fusealage and anywhere you may want extra strength good luck with your plane
Old 10-15-2002 | 05:08 PM
Thanks. I appreciate the help everyone offers in these forums.
Old 10-16-2002 | 12:43 AM
also epoxy the landing gear blocks and the fire wall,can mix alcohol with epoxy to fuel proof firewall and fuel tank area.
Have a goodun,John.
Old 10-16-2002 | 01:01 AM
Also, use epoxy for, firewall, main gear reinforcing and attatching tail assembly together.
Sig kits Ive built usually indicate in the instruction book the locations where epoxy is neccessary.
