 im so lucky... >
im so lucky...
im so lucky...
Old 08-13-2005 | 12:31 PM
Sarges_heroes2003's Avatar
Default im so lucky...
the club has got as many new traines as soloed members so to help us get soloed they decided to meet tonight. this is a first. for me I get off work at 5 and every one should start showing up around 6:30 ish. its cooler and a whole lot less humid than tha last time I flew so the plane should work great this time. just thought I would let you all know ill be out at the field flying!!!!!!
Old 08-14-2005 | 02:26 PM
Default RE: im so lucky...
well I am back!!
I got to fly (this makes two flights on the ole bird) and we had a problem. the plane would not idle down on landing so it hit kinda hard. the plane was not hurt but i put in a better mount today and some of these blind nuts things. tomarow I head out to O'reilys to get some lock tight. that should hold it down reall good.
Now the only thing that needs fix'in the size of the prop. they all over prop there engines at this field and it seems to work good.
