 First Warbird what should it be? >
Old 08-15-2005 | 12:50 PM
Flyboy76's Avatar
My Feedback: (14)
Default First Warbird what should it be?
Hi there i live in rural Saskatchewan and have recently gotten into flying RC planes. I started with a J-3 Cub from parkzone and i have to say that it is an awesome little plane. ( i have an advantage because living on a farm if i had to crash land i put it down in the crop across the road. ) I have since moved on to an hanger-9 RTF Arrow. I was going to buy the Alpha but the guy at HOBBYWHOLESALE in Edmonton talked me into the arrow instead. I have been flying it right at home for 5 months now and every night that it is calm i fly at least one tank through it. I take off right from my driveway and land on the gravel road that runs by my place. ( the RM does not gravel it very often so it works pretty good ) . I want to buy a ARF warbird that is one of the easier ones to fly and was wanting some advice on which one would be a good starter. I am currently making a grass runway for it. 5 months is not very long but i have over 150 flights under my belt and one minor crash (minor thanks to the barley field. !!)
Geoff
Old 08-15-2005 | 02:24 PM
Default RE: First Warbird what should it be?
If you can get it, I think that you would be a good candidate for the new H 9 Mustang trainer.
Old 08-16-2005 | 06:18 AM
I second the motion especially if you already have flying experience. Hangar 9 Mustang trainer!
Old 08-17-2005 | 12:35 AM
You might consider the VQ line of warbirds. I have the Zero and it flies very well. www.vqmodelaircraft.com
Old 08-17-2005 | 11:57 AM
My Feedback: (28)
Actually with my experience with the Arrow it lands with similar speed and characteristics as most of the Hangar 9 60 size warbirds. I've flown the P-40 the Corsair and the T-6 they all have alot of the same characteristics as the Arrow since the Arrow is a semi-aerobatic trainer. The taildragger part is a little interesting to learn but other than that I really think one of the above would work.
Old 08-17-2005 | 12:32 PM
mrbass111's Avatar
although i have not flown it the t-34 by hangar 9 was reccomended to me as an easy flying plane maybee someone else here can give some additonal imput on that model.
Old 08-17-2005 | 12:43 PM
Spaceclam's Avatar
a mig 29!
Old 08-17-2005 | 12:54 PM
I moved from an Arrow to the Hangar9 T-34. Not a bad transitional "warbird", but make sure you've got enough power (I went from a Magnum .46 XL in the Arrow to a .46XLS in the T-34) to get it off the ground. Once up in the air, I found it to be a bit "twitchier" than the Arrow, but very controlable once you get used to it. Landings are a bit hotter than the Arrow, and you've got to pay more attention as the Mentor will tip-stall if the speed gets too low. I'd also change all the plastic clevis's to metal, so you don't repeat my loss of elevator control at the top of a loop. The Mentor does a great vertical dive!
Old 08-17-2005 | 02:47 PM
Flyboy76's Avatar
My Feedback: (14)
thanks for the input i will take a look into all of your suggestions
i would really like to get the 60 corsair from hangar -9 beautiful plane
Old 08-19-2005 | 05:57 AM
Banned
i would choose a british SPITFIRE.best planes ever made
Old 08-19-2005 | 09:10 AM
ORIGINAL: fokker20planes
I 'third' the motion on the Mustang trainer. look it up on Horizon Hobby website. If you like warbirds, the H-9 P-40 is an awesome flying plane, might be a good third plane. Has very forgiving characteristics for a warbird model, will fly almost as slow as a trainer. I imagine that all the newer H-9 warbirds are like this.
Old 08-19-2005 | 09:39 AM
My Feedback: (7)
The H-9 60 size Corsair is a beautiful plane, and a challenging one. Keep it on your list for "down the road", however I would not recommend it as a first warbird.
Old 08-19-2005 | 10:23 AM
ORIGINAL: luke21
While the Spit is a lovely bird, it is not a good choice as a first warbird. It is a fast & unforgiving critter. The eliptical wing stalls simultaneously across the entire pannel, so there is little or no warning. It can easily stall in the final turn & on final approach if speed is not kept up. The airframe is so clean that it does not decelerate easily, so landings are very fast unless flaps are employed, & an attempt to flare to soon, in an effort to shed speed, can easily result in a stall & cartwheel. Take offs are also not trivial affairs & can be truly fatal if it is pulled off too quickly.
Chose something a bit more benign & save the Spit ownership for later.
Old 08-19-2005 | 11:07 AM
Fastsky's Avatar
If you don't mind to cinsider ARFs then check out the World Models planes. They are a sport version which means that they are more forgiving to fly than scale type warbirds. The T34 is fairly inexpensive and is a great flyer.
[8D]
Old 08-22-2005 | 10:07 AM
Flyboy76's Avatar
My Feedback: (14)
thanks for all the tips i will look at everything. i bought a Seagull p-51 after talking to a friend of mine that had one and flew his 1st. It is a nice plane that will slow down decent for landings. I put mine together and flew it this weekend and it flew great for me but i need some work on landings. Will practice my touch and go's.
Geoff
Old 08-22-2005 | 11:05 AM
hi guys im new also in this hobby after highe wing trainer i got world model T34 its great to fly and easy
Old 09-01-2005 | 12:27 PM
martno1fan's Avatar
luke get real man the spit is the best plane ever made BUT ALSO THE MOST DIFFICULT TO FLY.my advice is try the corsair ive heard a lot about this plane and its probably the easyest to fly of all of the war birds!!!.
THE SPITFIRE IS THE CREME DELACREME OF PLANES THOUGH!!!ONE DAY LOL
Old 09-02-2005 | 05:18 AM
Banned
i love spitfires(number 1 plane)[sm=thumbup.gif]
Old 09-02-2005 | 07:32 AM
ORIGINAL: luke21
Me too -- but not as a 1st warplane.
Old 09-02-2005 | 07:34 AM
Banned
i no , i no.BUT I STILL WONT 1.EVEN THOUGH IM STILL ON A BUDDYLOL
Old 11-23-2005 | 11:40 PM
What model Spitfire are you flying
Old 11-24-2005 | 08:13 AM
Fastsky's Avatar
I have a Zero, Seafury, and a Great Planes Stuka. The Stuka is by far the easiest to fly but they have discontinued the model.[]
Old 11-24-2005 | 08:15 AM
I would not fly the spit as a 1st warbird not to forgiving. the corsair I dont think so either. The p51 yes, as a first warbird or the P47 I heard was a good one also.
Old 12-03-2005 | 10:41 AM
djyoung's Avatar
If I may, here are my suggestions from my experience.
I'd say Kyosho Mustang is a good first.
Any mustang is a good first exept World Models. They seem to be a bit heavy but if youre experienced then thats no problem.
Hangar 9 is great but the retracts.
I started with a pt-19 and that was my 2nd plane and I wished I'd started off with the Kyosho Mustang.
Old 12-03-2005 | 11:58 PM
Lukes still around. Incredible! Keep up the training. You'll fly a Spit someday.
