4" of receiver antenna snapped off, is this a problem?
MI
Hello,
I was removing one of my trainers from the car and part of the antenna was stuck under my flight box. When I removed the plane from the car, SNAP!...about 4 or 5 inches of the end of the antenna was ripped off. Does this affect the range at all? Should I solder it back together? Or does it even matter? Any suggestions or past experience would be helpful. Thanks in advance.
Kattatget
Kattatget
yes, solder it back and shrink wrap it, also make sure it didnt break any where else that you cant see through the coating, (range check the heck out of it)no glitches!!
short anser is yes get it repaired. is there anyone in your club work in electronics? simple repair but needs to be done correctly. not flying while rec. being repaired is better than not flying because of a crash and a whole lot cheaper.
MI
Unfortunately, I don't belong to a club. Just me, my father in law and his 28 acres, so Ill be repairing this one myself. Soldier and shrinkwrap....doesn't sound too difficult. You mentioned "Doing it correctly" is there anything else I should know before I get started?
It's a very simple fix. Just avoid overlaping too much (About 1/8" should do it)
If you're a soldering rookie, here's a quick "How To"
http://www.rcuniverse.com/magazine/a...article_id=172
If you've soldered before, no prob.
I recieved this when I asked the same question last year to Futaba. This is if you want to replace the whole thing.
flyer495th from RC Universe Discussion Forums - Ask questions and forwarded a message to you at 10/6/2004 12:28:27 PM:
RE: Busted Antenna wire on Rx....advise needed - by Krysta
Hi Bob,
While we can not recommend that anyone change their receiver wire, as this can cause serious problems such as loss of reception and major interference issues, and also void any warranty that you may have on your radio system.
But, if you are very good with a soldering iron, you should replace the COMPLETE antenna at the board, not just solder at the cut. Also after doing so, do a thorough ground check, you would want to look for 22 gauge wire, and the length will be:
approximately 19 1/2" for surface
approximately 39 1/2" for Air
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Hi Bob,
Sincerely,
Krysta
Banned
just buy some new recever wire and solder it to ur recever BUT MAKWE SUR IT IS THE SAME LENTH AS YOUR OLD 1.
