 Chaning props on Alpha60 >
Old 09-25-2005 | 07:53 PM
Default Chaning props on Alpha60
I am new to flying. Friend at flying park suggests me to change from 3-blade prop to 2-blade. I found that the prop shaft of my evlution 61 is bigger than a prop I bought (12-6 graupner). Am i having the wrong prop or it need to be drilled to fit? Please advise.
Old 09-25-2005 | 08:00 PM
Default RE: Chaning props on Alpha60
Your friends are right switch to a 2 bladed pro they are less expensive and they are easier to find then 3 bladed props... but im not sure about what you should do to your plane im new to flying also
Old 09-25-2005 | 08:02 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Nope, you don't have the wrong prop. You just need to enlarge the hole on the prop. Yes, you can drill the hole out but I wouldn't recommend it. It's easy to get the hole off center which will throw you prop out of balance. If you can try using a prop reamer to enlarge the hole. Just remember that the reamer only cuts in one direction, so don't turn it backwards. You can find them at Tower hobbies with this link [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK248&P=7[/link]
Hope this helps
Ken
Old 09-25-2005 | 08:03 PM
echobot's Avatar
You can drill the prop out to the proper size or you could use a prop reamer.
Here is a link to some prop reamers.
http://www2.towerhobbies.com/cgi-bin...er&FVPROFIL=++
Old 09-25-2005 | 08:16 PM
Thank you guys for all answers.
