Balance >
Balance
Balance
Old 11-08-2002 | 02:03 AM
mstroh3961's Avatar
Default Balance
Hi all! I have a four star 60 under construction, and I would like to know if I should balance the wing before covering? It seams to be heavy on the same side that the engine will be mounted. balance point is approx 3/4 inch from center, this is the wing only at this point.
Thanks for looking!
Regards
Mark
Old 11-08-2002 | 03:27 AM
Default Balance
I would finish the plane then balance it,move the battery and or add weight,if wing needs tip weight then I would add it.
Old 11-08-2002 | 03:31 AM
Hypter's Avatar
Default Balance
Yes, complete the plane, install all the radio equiptment, fuel tank and engine. If its tail heavy, try and move everything that is moveable, foward before adding weights.
Old 11-08-2002 | 03:36 AM
mstroh3961's Avatar
Default Thanks
Thanks guys!
Mark
