WOW! Another Sig Somethin Extra Build
AZ
YES! But another Sig Somethin Extra kit build. I wasn't sure if I was going to post my progress on RCU, but I figured why not. Here's what I have in mind for mods:
-Sheet the turtle deck
-Counters on both rudder and elevator
-Sullivan tailwheel
-Considdering a custom cowling
-considdering a better main gear
Thanks to krossk for sending me some pictures on how he did his counters, and thanks also to kiswa for the 3-view picture for the SSE.
I started on the plane about 10 days ago, but I spent the last 7 days in Cabo San Lucas on vacation (I know, lucky me) so my progress is only limited so far. I have the right wing started and the ribs are in place.
I am also finding that I am challenged with a cluttered workspace... I got married recently so I have a ton of left over decorations and such that I am finding I am "dealing" with about my garage... yippie
-Sullivan tailwheel
AZ
RE: WOW! Another Sig Somethin Extra Build
ORIGINAL: Digger44
That Sig is turning out to be a very popular plane around here. Nice color scheme, good luck with the build and have fun.
Also:
Right trailing edge getting applied.
Good luck on this first build, it's way fun! You might consider enlarging the rudder. I added 1 1/2" to mine with very good results. Your intended color scheme is similar to mine, so I hope this photo helps in the decision making.
AZ
Looks good... 2 inch squares is what I was thinking on using too.
As for the rudder... I think I will be adding an inch or so to it. I'll figure out the exact amount when I get to that part.
Here's to watching glue dry.
My Feedback: (27)
WI
Looking good. So what are you going to use for power? If you are going with a larger 4 stroke and need prop clearalce, consider the DuBro .40-.60 gear. It looks decent, costs considerably less than c/f, and is a lot lighter than the stock set.
AZ
ORIGINAL: krossk
My Feedback: (9)
Looking good so far. I have the ARF. I am running a ST .51 with a MA 12x4 prop. This has been a good combo. It hovers it and has plenty of straight line speed. Mine is easier to hover than my Funtana or Ult bipe. I have Saito 72 ready to go. The .51 is on it's last leg. Good luck with the build.
David
David
AZ
Thanks for the feedback!
Here's a general question to anyone out there reading this thread:
Has anyone replaced the j-hooks with a nylon thread and flat nylon nut setup? For instance: say replace the wooden dowls with a nylon stock rod that is threaded and epoxy it in place, and then create a reinforcement in the fuse to seat a nylon nut against?
Also: new possibility for a mod: Since I am considdering a cowl, I may also put in afuel tank hatch.
My Feedback: (27)
WI
Don't bother with the hatch. Just do a little trimming on the tank plate and the former at the rear of the opening. Then don't use a lot of glue attaching the wing tube in the fuse. Mine is actually pretty secure just from the covering ironed on the outer edges. But I do intend to add a drop or 2 of wood glue to the tube to the servo tray. With the tube out of the way, there's a ton of room the get the tank in/out
and you won't have to worry about weakening the front end of the fuse.
As for the J-bolts. I just added a blind nut between the inner and outer root rib and will use a lock nut against the wing to secure the J-hook. Then a nylon zip-tie will keep the wings from going anywhere.
AZ
ORIGINAL: krossk
I was more looking for a less disposable way to keep them in place... but heck, zip ties are cheap anyways.
Here's my current SSE build:
[link=http://www.rcuniverse.com/forum/m_3540270/anchors_3540270/mpage_1/key_somethin%252Cextra%252Cbuild%252Calong/anchor/tm.htm#3540270]My SSE[/link]
AZ
Right Wing Sheeting Shots.
I was a little concerned about my leading edge sheet. This is my first and while I have great contact along the ribs and spar I think I may have to work it out a little on the front... any advice?
The steel spring works. I've seen it in action and it's a good way to keep the wings together.
For fuel tank I have the Dubro 8oz, fits nicely and can be slid out from the tank compartment (Install wood bracket behind tank so it's not coming out in flight, don't forget to pad it in with foam)
Your sheeting looks ok, you'll sand it later.
AZ
Thanks a ton.
Anyone invest in one of those multi-angle bar sanders? I think Great Planes makes it? I made my own bar sander out of a 20" piece of square bar... but wondering if I should invest in the countour sander too...
My Feedback: (27)
WI
Nah, to me it wasn't worth the $. I got this little sander in my Tiger2 kit and while it may not be as fast as the contour sander, it works pretty well if you are careful and take your time.
My Feedback: (13)
That contour sander is a waste of good aluminum. You'll see more use out of the straight bars. The long one (22", I believe) makes short work of truing up a wing or other long surface. Its a really useful tool.
I have two of the twelve-inchers always handy; one with 100 grit paper, the other with 220.
Here's trick for quick-changing the paper, which can be a major PITA. Lock the bar upside down in your vise, and heat the paper thoroughly with a heat gun or hair dryer on high. That will soften the adhesive, and the when the sandpaper starts to curl at the ends, just peel it right off the bar. Allow to cool, clean the residue off the bar with acetone or lacquer thinner, and you're ready for a new piece of paper.
If you "jump the gun" and start to peel the paper before all the adhesive has softened, you will leave a mess when it tears. No drama; just use a single-edge razor blade to scrape it off. I buy those things by the hundred at Home Depot.
I only use a long bar sander, just the flat, standard from GreatPlanes.
It works good and is all you need to shape the wing, trainilg edge, ailerons etc...
A tip is to CA a small piece of sandpaper to the shaft of a screw driver.
This makes a perfect tool to enlarge holes and smooth small curves.
My Feedback: (9)
I have several bar sanders but use something different for long pieces like sheeting. The front of my work bench is 2" thick. So i took some 2" wide sand paper with sticky on the back and put it on the work bench. Now I can hold the sheeting evenly with both hands and move it back and forth.
David
David
AZ
Good to know about the countour sanders. I think this next shot will have in it the bar sander I made from left over square stock... but not sure it'll do the complete job because it's only 1" wide...
None the less.... Right Wing, top sheeting in place... flipping over once the glue is Dry.
Also, Shot 2: I noticed there is a little bowing in the sheeting between W1a and W2... normal? Advice?
Thanks!
Thanks!
