 Nexstar Rudder throws >
Old 12-29-2005 | 01:19 AM
Default Nexstar Rudder throws
Hi Guys,
Just completeing my first plane and have problems with Rudder throws.Ive mounted the horns exactly where the instructions stated and find that my throw in one direction will met the 19mm spec but the other direction i only get 5mm.I know why if im not mistaken and wonder why others havnt mentioned it.It appears that the thickness of the rudder compared to the Fuse is to thin.Consequently when the horn is mounted the portion that has the holes touches the fuse just below the bottom hole.I was just going to turn it around but saw a post that said the hole should align with the hinge so thats not a good idea.Packing of the control horn seems to be my only choice.
Ive enclosed a pic of the area from a review image.Ive arrowed the area that is contact with fuse on my plane.My control horn looks very much like theirs.So the only conclusion i can come to is that the rudder thickness is to thin.Why havnt so many others complained.
Packing seems to be my only choice,has anyone else noticed this .Any comments to help out someone whos knows little would be very nuch appreciated.Ive read many posts and have learned alot.Thanks to all.
Rgds
les
Old 12-29-2005 | 01:48 AM
Default RE: Nexstar Rudder throws
Not sure what you mean when you say 'packing the control horn'. I would guess you mean adding a piece of wood or something under the control horn to move it away from the rudder. But that's not really necessary. Just use your razor knife and cut away some of the control horn so it doesn't touch the fuselage. You won't need to use the lowest (closest to the rudder) hole anyway.
Something else I would mention though, it doesn't look like there is very much of the pushrod screwed into the clevis for the rudder. Make sure that clevis will not come off the pushrod. You don't want to lose control of the rudder while in flight.
Try to get all the control surfaces as straight as you can with mechanical adjustments (twisting clevises, adjusting servo arms, etc.). Then make the final small adjustments with the radio trims. Good Luck!
Old 12-29-2005 | 02:49 AM
MikeEast's Avatar
sortof like this
Old 12-29-2005 | 07:02 AM
Hi!
Yeah! Thats right!
Jan K
Old 12-29-2005 | 08:53 PM
Your right about adding a what you call a packing between the control horn and rudder I have added just enough wood spacer to clear the fuse. It's OK now. Just do it!!!!
roltech
Old 12-30-2005 | 02:14 AM
BigWes's Avatar
ORIGINAL: jaka
Hi!
Yeah! Thats right!
Jan K
Yup, I agree with jaka. Trim the corner off of the horn and you'll be ok. Remember this if you start adding 'shims' then you may run into a problem with your horn retaining screws not being long enough. Jaka has given me good advice before and I am sure he will do the same for others. Thanks Jaka. I may have not mentioned (Jaka) it but my sonic 500 did fly really good and my throws ended up closer to yours than anyone elses. I have a Nexstar too and mine will do almost the same thing. But during installation I kinda figured in for this and had placed my horn just a bit further back. The rudder is not too thin nor is the fuse too thick. It is all good. The Nexie is an odd craft in some aspects but with some mods is a quite decent plane. I think it is a large plane for the engine size but it does quite well with it. Anyway, don't get too carried away with the rudder on it. I seldom use a rudder. Only during certain manuevers and during landing and takeoffs. I may be a poor pilot who knows. I think if you trim the corner of the horn without getting too deep you'll be just fine. Main point being you dont want you servo working too hard and draining the battery down too quick. Remember this about the Nexie and you can try it if you don't believe it. If you throw full rudder in flight it will list in that said direction and the nose will drop hard as well. That isn't a bad thing if you loose aileron control but it can be unnerving to a student pilot. I have had models that would actually appear to fly sideways with full rudder and they would not drop a wing or the nose. I have always considered these type of planes to be good designs.
Good luck with it dude,
Wes
Edit to add: Before you fly that thing you may want to smooth out the wrinkles in the covering with a heat gun. It will still fly without doing it but it will give a better overall impression if you take it to the flying field without all of those wrinkles. That is just my opinion and it is probaly worth crap....
Wes
Old 12-30-2005 | 09:25 PM
No the screws on mine was long enough no problem , in fact I can also use the lower control hole and it will not touch the fuse. but I have never alter the control horn to clear the fuse, but if someone has tried it and it did not weaken the part then it must be OK.
roltech
Old 01-05-2006 | 02:35 AM
Hi Guys,
Thanks for the replys,took up your advice.Just waiting for my instructor to return from holidays and will see if it flies.
Rgds
les
Old 01-05-2006 | 05:41 AM
Iwik, Iwould bring in the rudder clevice 2 holes closer to the rudder to give the rudder more throw. Especially if you are flying from a grass strip. I have trained 3 students in the last year with that model , and had to do that adjustment to all of them. If your radio has expo, then put in 40%expo to ease the stick movement around centre. The model will love it and so will your instructor, hence so will you .Happy flying and smooth landings , it is a good model to fly .
