 aps or psa or asp .46!!!???? >
Old 01-08-2006 | 08:44 PM
Mchwind Chimes's Avatar
Default aps or psa or asp .46!!!????
my uncle gave me this motor, its a .46, and on the side it says asp or psa or aps something like that, what the real name? any good?
Old 01-08-2006 | 08:47 PM
piper_chuck's Avatar
My Feedback: (12)
Default RE: aps or psa or asp .46!!!????
Perhaps it's ASP? Made at the same plant as Magnum, SC, and a couple other brands. Should be ok.
Old 01-08-2006 | 09:10 PM
is it bigger than an mds .40?
Old 01-08-2006 | 09:37 PM
My Feedback: (12)
If you are asking about physical size, I don't know. If you're asking about displacement, yes, a .46 is larger than a .40. These numbers represent the engine's displacement in cubic inches. Note that displacement is only loosely related to power. While in general, engines with a larger displacement will have more power, there are many different levels of engines. It's not hard to find a .46 engine that has more power than a larger .61 engine. However, the .46 will most likely cost more money.
Old 01-08-2006 | 11:21 PM
alrighty thanks, anything else.
Old 01-08-2006 | 11:36 PM
My Feedback: (12)
Welcome. Was there another question?
Old 01-09-2006 | 09:29 AM
Fastsky's Avatar
ASP has been making engines for a number of years. The original ones wern't very reliable but I have to give them credit, they do keep trying improved versions. The latest version is called "Super Series". I have a 52 size and its a little touchy to adjust but turns the prop scary fast once its set.
Old 01-09-2006 | 04:08 PM
sounds cool. i hope it will do good for me. anyone no the specs for a .46 non s
