new engine running question >
Old 11-27-2002 | 10:28 AM
Default new engine running question
I finally got my new Thunder tiger 46pro running on the bench with a wire to the throttle... I was tuning well trying to tune... Do you only adjust air mixer at full throttle and then do that small ideal screw at Idle. I was adjusting the air mix but it didn’t seem to do much. I started at about 2 ½ turns out and run the first tank of fuel through it. I seem to run OK but spits a lot of oil out the exhaust.
Do I wait until I have run 2 tanks through before I start revving the engine and adjusting mixes??
Any tip would be great the instructions with the engine are a bit vague
Old 11-27-2002 | 10:44 AM
Found a post with a good discription
http://www.rcuniverse.com/showthread...262#post471714]
Old 11-27-2002 | 01:57 PM
read the instructions.
