Engine Problem!! >
Engine Problem!!
Engine Problem!!
Old 11-28-2002 | 07:55 PM
Default Engine Problem!!
Hi all, I am having problems starting my engine. It starts up and then quits.....can someone tell me how to adjust the needle valve? Thanks for the help.
Old 11-28-2002 | 08:03 PM
Open needle 2 and 1/2 turns. Turn on transmitter & receiver. Fully open throttle. Place thumb over carb air inlet and turn prop a few revolutions by hand, until fuel fills line to carb.
IMPORTANT-Reduce throttle to 1/3. Put glow plug igniter on and start engine.
Old 11-28-2002 | 09:11 PM
2 and 1/2 turns....is that turning it anti clockwise, 2 and 1/2 clicks?
Old 11-28-2002 | 09:23 PM
My Feedback: (12)
Default Starting engine
No. Not clicks. Close the needle valve completely first (clockwise). Be careful and just turn it until it stops with no real pressure (too much pressure on some engines will bend the spray bar). It should be 2 complete turns (360 degrees each) and another 1/2 turn (180 degree). Some engines require as much as 3 turns. It sounds as if the engine is burning the prime and then quitting.
Old 11-28-2002 | 10:31 PM
We have to know what size/kind of engine it is. Some need up to 4 turns.
Old 11-28-2002 | 11:07 PM
It's a OS .25. Thanks for the help, I'll try this in the morning, is there anything else that i need to check?
Old 11-29-2002 | 01:08 AM
Go to: http://www.osengines.com/faq/product-faq.html#q155
This will answer all your questions.
Fred
