 CA on Covering >
CA on Covering
CA on Covering
Old 03-27-2006 | 11:21 PM
shakes268's Avatar
Default CA on Covering
Well here is a newbish thing to do even after flying for over a year....
I got a little overzealous with some CA and it ran onto the covering. Any good way to get it off? Will debonder take it off without harming the covering? Or should I just let it sit and flake off eventually?
Old 03-27-2006 | 11:23 PM
piper_chuck's Avatar
My Feedback: (12)
Default RE: CA on Covering
I've had good results using a little acetone on a rag.
Old 03-27-2006 | 11:24 PM
shakes268's Avatar
Thanks, normally I wouldn't worry about it but this plane is my first gasser so I'm being a tad picky
Old 03-27-2006 | 11:36 PM
AQ500's Avatar
I'll second the acetone. I always keep a bottle handy. Just watch out on the older ARF's with the sticky vinyl covering. Sometimes the color scheme will run off. I've had no problem on Monokote or Ultracote.
Old 03-27-2006 | 11:38 PM
shakes268's Avatar
It's ultracote so shouldn't be a problem them. Thanks!
Old 03-27-2006 | 11:41 PM
tuwood's Avatar
I used debonder on blue monokote with no problem. I would try to find a small spot behind the cowel or somewhere inconspicuous & test it to make sure it doesn't cause any problems.
Old 03-28-2006 | 08:11 AM
Hey, tuwood, you ought to look for acetone the next time you're in a home improvement or hardware store. It's very much cheaper than debonder. I think a quart is just a couple of bucks. And it's got other uses. For example, it thins epoxy WAY BETTER than drug store alcohol does.
Old 03-28-2006 | 08:17 AM
tuwood's Avatar
ORIGINAL: darock
Will do.
I have a bottle of debonder I bought a while back & have got quite a bit of mileage out of it. When it runs out I'll try some acetone.
Old 03-28-2006 | 09:29 AM
AQ500's Avatar
The fumes are great too
