Flyes to the left
OH
I have a 55" wingspan .40 trainer. It flyes to the left. Can not get it to go right enough to turn
it right. The wing is not twisted. I thought I balanced it good. It all looks good. Can any one
Help me. Thanks
ORIGINAL: mckibben
Help me. Thanks
Help me. Thanks
-do you have a 3-channel or 4-channel plane? (Does it have a rudder?)
-have you tried turning right with the engine at idle?
-have you flown in calm wind conditions?
-if you have a 4 channel plane, are you trying to correct with ailerons? or rudder?
If the engine has no right thrust, it will pull the plane to the left under many conditions.
If your vertical stab is only a degree off, that will make a big difference.
I'll stop here & follow the thread.
Good luck,
Dave Olson
OH
My trainer uses a futaba 4exa radio Its a top wing with a rudder It's a tower trainer. What is
verical stab. When I flew it I had a 10 mph wind. It wants to turn right with the arons but
will not go all the way to the right. I never flew it in calm wind. I am a builder by heart. I built many CL planes witch fly great. This is my first RC project.
ORIGINAL: mckibben
2nd, check the vertical stab (the part the rudder is attached to ) to insure it is aligned properly with the C/L of the plane. Run a piece of string from the center of the fuselage at the front of the plane (the forward top portion of the main wing is fine ) to the center of the fuselage at the tail. The vertical stab should line up with the string.
3rd, block the FUSELAGE so it is level (do not use the landing gear ) from side to side. Check that the main wing AND the horizontal stab (the part the elevator attaches to ) are also level.
4th, if the first 3 check out ok, check the engine. Many of the motor mounts in trainers have plates that go over the mounting lugs of the engine. If your trainer has this type of set up, make sure the engine is at 90 degrees to the firewall (the part the motor mount bolts to ). If the engine is not at 90 degrees, adjust the engine so it is 90 degrees to the firewall, if the engine is at 90 degrees to the firewall either loosen the plates and adjust the engine so the front of the crankshaft is about 3/32" - 1/8" to the right of the centerline when looking from the rear OR if your engine bolts directly into the motor mount, insert a small washer between the motor mount and the firewall at the top AND bottom of the LEFT side of the motor mount (when looking from the rear ). Your local hardware store will have a selection of different thickness of washers in the fastner section (a #6 washer should work fine with the motor mount bolt - don.t forget to put some locktite on the bolts before rebolting the motor mount in place)
Then go fly the plane after the adjustment(s) and readjust as needed. The engine will be the easiest to adjust at this point if you needed to remove/reattach the vertical stab.
This should solve the problem.
TX
Once you have made all the adjustments suggested in this thread, fly it. If it still turns to the left, observe if it wants to "roll" to the left, or "flat" turn to the left. If it rolls, your ailerons need to be tweaked, initially with the transmitter trim, and then manually on the ground. If it just wants to turn without rolling, it's the rudder, vertical stab, or engine offset. Make sure it's headed directly into the wind when you observe it. I had a Lanier "Comet" that I was stupid enough to buy and it had a warped and twisted fuselage. Finally got it to fly right by adjusting the control surfaces all out of kilter. Glen
