balancing my scratch built? >
Old 12-15-2002 | 04:38 PM
My Feedback: (10)
Default balancing my scratch built?
I need some ideas about balancing my plane built out of foam poster board (see pic) . Should I keep the nose heavy? Do I balance at the main spar in the wing? I really hope this thing flies. I figured it will be a good plane to learn on and I wont be too upset when I crash it. By the way, it is VERY strong and light and only cost me $35 to build the plane.
Old 12-15-2002 | 11:18 PM
My Feedback: (49)
Default Balancing
You should be able to use the spar to balance your plane. It should be a little nose heavy. This will make it a little more stable in flight.
Old 12-15-2002 | 11:28 PM
My Feedback: (30)
I made mine from probably the same stuff.
I flew mine today. I just have to add some down thrust and make it less sensative. It is a fun fly type airplane that I specially engineered for me.
If that plane balances well on the spar and has a good amount of thrust deflection if will fly.
My friend has horible looking aircraft that were crashed repeatedly. He used a twig for the leading edge of one and he said it flew great. It also had a new front end that was looked like a box. The point is that if you saw some of them you would have no doubt that your plane will fly.
Old 12-16-2002 | 01:40 AM
On a straight wing,measure from the leading edge back 22% to 28% of the wing cord.22% being nose heavy ,28% being tail heavy.
Old 12-16-2002 | 07:01 AM
General rule of thumb - CG = 25% - 35% of the wing chord from leading edge.
http://www.uoguelph.ca/~antoon/hobby/pmdesign.htm
<Edit> Remember though, this only applies to straight wings, with a constant chord width. Do not use this "rule" for tapered wings, swept wings, wings with washout, etc...
Old 12-16-2002 | 03:27 PM
My Feedback: (10)
Thanks everyone. I will try those ideas today and I will let you know how it flies, when I get some decent weather to fly in. Snowing here today.
Old 12-16-2002 | 03:52 PM
aircowboy,
Where do you fly?
