 Thrust line >
Thrust line
Thrust line
Old 05-24-2006 | 04:58 PM
Default Thrust line
The guy at my field sggested that I put my engine on a little crooked so my plane wont pull to the right as much, Is he right and do you have any opinions on doing this?
Thanks, Dave Trimmer
Old 05-24-2006 | 05:10 PM
Default RE: Thrust line
yes, use a couple of washers under the mount. Works like a charm!
If you ever look closely at the scale aerobatics planes in the 35-44% range, you will see that the engine is mounted around 1 1/2 - 2 degrees off center.
Old 05-24-2006 | 05:24 PM
Missileman's Avatar
Offset thrust is common in RC airplanes. Some designs have it built right into the firewall others you can add a couple of washers or a shim.
Old 05-26-2006 | 04:27 PM
Is that Right thrust or Left thrust ?? I use Right thrust in my 1/4 Patty. Are smaller birds different ?
I believe Dave has another problem if he needs Left thrust .
Matt
Old 05-26-2006 | 08:58 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Most planes will use right thrust. and also some down thrust too.
Ken
