 slide in stab >
slide in stab
slide in stab
Old 06-10-2006 | 11:31 AM
Default slide in stab
I am curious if when putting in a slide in stab i should just wick in ca as the directions state or should i also try and add some epoxy as well.. Thanks in advance Kieth
Old 06-10-2006 | 11:38 AM
My Feedback: (13)
Default RE: slide in stab
personally, I like to use an epoxy in this application. I have had CA joints fail after a while.
Old 06-10-2006 | 12:37 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
For putting the stab in you need to use epoxy to attach it.
Ken
Old 06-10-2006 | 12:59 PM
ok sounds good...just to be clear i am talking about the horizontal stab not the vertical..last plane i did i epoxied it just wasnt sure how much good it did because there isnt much surface for it to glue to Kieth
Old 06-10-2006 | 04:57 PM
You have cut away any covering in the glue area, RIGHT ?? Glueing wood to covering or covering to anything doesn't make a good glue joint. Think about it >> you glue to the covering and all that's holding is the adhesive on the covering. Good Luck !! ENJOY !!! RED
Old 06-10-2006 | 05:30 PM
RCKen's Avatar
My Feedback: (9)
ORIGINAL: red head
Very good advice Red. And to add to what he said, do not use a knife of any sort to cut away the covering from the stab surface. It's too easy to cut too deep and score the wood underneath, which can lead to the wood breaking while in flight. Instead use a soldering iron to melt through the covering to remove it.
Hope this helps
Ken
Old 06-10-2006 | 05:52 PM
I would of course remove the covering..in the instructions is states to wick in ca on the horzontal stab...not epoxy which is why i was asking thanku for the good advice i will go ahead and epoxy it Kieth
Old 06-12-2006 | 07:41 AM
TNRabbit's Avatar
I would recommend a good 30 or 60 minute epoxy to allow it to work into the wood well...
Old 06-12-2006 | 02:38 PM
Manufacturers sometimes specify CA where you should use epoxy, and I'd guess it's an attempt to shave the build time. CA would work, but epoxy is better here. Continue to check the alignment as the epoxy cures.
Old 06-12-2006 | 11:36 PM
CARS II's Avatar
My Feedback: (7)
You can clean the overflowing epoxy with alcohol and paper towels right after you are done installing it, don't forget, make sure it is lined up with the wing.
